It's a little trick, i make use of it to upload Stealers/Keyloggers/Zombies servers. It's kind of new way used those days in the Phishing World, so beware when downloading something fellow geeks.
Lets start:
I have a file server.exe and i want people to download it but they might doubt even thought i can crypt it to make it undetectable but imagine you have an .mp3 file or .jpg file that NO ONE will doubt about it so any person will open the file directly. To do this just follow the steps below.
1- Change your server extension from .exe to .scr , don't worry .scr is still executable, it's better to use .scr so it will look more legit.
2- In windows Vista/7, Start ----> Accessories ----> System Tools ----> Character Map.
3- Scroll down and find the "U+202E: Right-To-Left Override" character:
Click "Select" and then "Copy".
4- Now choose to rename your file, and paste the copied character right before the ".SCR" (press ctrl+v to paste)
5- Then type "3pm" (without the " ") and press Enter. Now it should look like this:
You'll get as the result in the picture above.
And ofcourse you might want to change the file icon to look like a real mp3 file.
