VincentKeyboard
What is a recommended software for cloning windows partitions? I plan on moving my windows installation from a 1TB disk to a 2TB disk.
It has a 100MB efi partition, a 530MB recovery partition, and the rest is the windows partition.
Any software that can clone the whole thing to a new disk while keeping the same layout including the recovery partition?
I would like a recommendation that someone has tried it themselves.
Thank you.
nuclearcat
On linux i use gparted, it should understand windows partitions as well. I think some liveusb with it exist for such job.
P.S. Always make backup first and goot luck
rolf
I use dd on Linux normally.
Search the forums, this question has been asked and answered many times.
VincentKeyboard
yeah, I used e2image and dd on linux. I'll search the forums for windows alternatives.
duke-of-bytes
I always use aoemi backupper..works like a charm
NoReGreT
