bigjudge Hello everybody. Is anyone having issues downloading from Mediafire latley (less than a week). I have no more resuming capablities and sections ( I use Free Download Manager (FDM). I thought that Mediafire changed their policies. Tried the same download link at a friend's house (Ogero) and it is working perfectly (resume plus sections). Please advice if you have any solutions. Thanks in Advance.
m-sabra Try to install hotspot shield,i have it running almost all the time,it overcomes almost any ISP,IP or network blocks.
xazbrat The only problem with hotspot shield is that it limited in the data that you can receive each month (~5 gig)--once you go over the limit, you will either have to pay for their upgraded plan or use some of the hacks available online.
bigjudge Thanks for the suggestions, I think i need to find a good VPN. Just wondering, any other terranet users are having the same issue?
