ziadomran
I'm noob in programming codes and those things. I just need a code that write a .txt file for numbers from "00000000 to 999999999999)
Any help is appreciated!
Thank you in advance anyone!
P.S: if someone posted a code, just tell me how to put it in my computer; e.g: 1- Run command prompt etc..
And if any program is needed, please mention it.
mesa177
We're not here to do any homework. What we can do is help you out in coding; show us your code and specify where you need help.
ziadomran
The thing is: I don't know how to program.
I'm sorry, I don't mean it in that way.
WizaRd
What you are asking is impossible without providing at least the language in which you want the code in.
Like mesa said, we're not here to do your homework. If you are not good in 'programming code and those things' then I hardly see any excuse for at least figuring out where to start.
Your course has a book I suppose, that's a good starting point... right?
ziadomran
Actually I'm still in school, I just want to do create a .txt file for every combination of numbers.
Hmm, let's say I want the code in Python language or HTML (those are the only language's names I know), what the code will look like?
ziadomran
Joe
@ziadomran:
We're not going to do your homework for you.
The best we can do is to help you if you decide to learn programming. For the rest, you're on your own.
If you want to know where to start, use the search feature of the forum, you'll find several thread where 'learning programming' is discussed.
