Inspired from my thread i decied to create a thread which will help new linux users
1)Download the proper nvidia driver
2) press CTRL + ALT + T to lunch terminal (cmd)
and type
sudo gedit /etc/modprobe.d/blacklist.conf
sudo = run the file with elevated permissions (as admin or root in ubuntu)
3) now add these lines
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
Make sure after the last line you add a space (press enter) and save
4) Remove older nvidia dirver by using terminal again
sudo apt-get --purge remove nvidia-*
5) Restart your computer
6) After you finished downloading the proper driver move it to your desktop (to make ur life easier)
7) Type in terminal
cd ~/Desktop/
then type "sudo sh NVIDIA-Linux-x86_64-285.05.09.run"
and press enter
It will make an error about x server bla bla igonre it and press enter till you get out of the error
8) go back to the terminal again and type
sudo stop lightdm and press enter
9) Press ctrl + alt + F1 and type your username and pass then type cd ~/Desktop/
10)type
11) it will ask if you ant to disable nouveau driver press ok it will then make an error and u will return to a black windows without the ability of typing . There press CTRL + ALT + delete to restart your pc
12) Go to terminal once again and type
sudo stop lightdm then press CTRL+ALT+F1 and type ur login info
there type cd~/Desktop/ and type
sudo sh NVIDIA-Linux-x86_64-285.05.09.run and install the driver
Result
To access the driver press the super key (windows key) and type nvidia and click on the application
