sinjer
Hey,
i tried everything to get my cod blackops to work online, including port forwarding, reseting the router, changing the settings on the ps3, enabling the dmz on the router... every possible way and still its not working.
my nat type is 2 and without firewalls..
im willing to pay 50$ to whoever can come fix it for me, i live in beirut area.
reply here or to my inbox your contact details.
cheers.
Chup
i'll help you out here dude...
Gamers help eachother , don't mention money again -.-
Just help me out a bit on giving me specific details :
1- Can you sign in to the playstation network ?
2- who's your ISP ?
3- How is you ps3 connected the internet ( Ethernet cable ? or wifi )
4- Can you play online on games other than cod ?
The-MMMs
although i could use 50$, my conscious is telling me not to take advantage of your generosity
anyway, with the above, please include Modem/Router model
also the region of the PSN account your using, along with the region of the game (its on the spine of the DVD case) it should be a black square with a globe and number in it.
sinjer
thanks dude, for real.
1- no i can't
2-sodetel 512speed
3-wifi
4- yes i played killzone3 , mortal kombat nothn else worked with me.
Chup
well then your problem is connection to the internet
go to network settings- internet connection settings- wifi - manual - *find your router* - input router's wifi key - and everything else as default.
Test it and let us know what you get
sinjer
um tp link TL- wr541g
the region is i think zone 1
sinjer
ok i did tht. i got
succeeded
succeeded
succeeded
upnp not available
nat type 3
download/upload " * "
and then cod connects normally , when i search for games it does tht but just never joins and they write no available sessions error
Chup
Repeat the same steps i stated earlier
and when you get the Upnp , enable it .
And try again
GO !
sinjer
easy or custom ?
Chup
go for easy this time
kdawg4-956
you can either enable UPnP or just connect the PS3 to your to your router via ethernet cable
Chup
kdawg4.956 wroteyou can either enable UPnP or just connect the PS3 to your to your router via ethernet cable
unlikely, because he would have tried that a long time ago...
i'm guessing his router is relatively far from the PS
sinjer
same results
upnp not available...
shld i try going in the game ?
Chup
No, you should go to your router's settings and enable upnp
sinjer
Chup wrotekdawg4.956 wroteyou can either enable UPnP or just connect the PS3 to your to your router via ethernet cable
already tried data cable from modem to ps3 , only difference was nat type went from 3 to 2 and game still doesnt connect.
im trying now cable via router instead of modem and willl test at easy with upnp enable.
sinjer
upnp in enabled in router settings.
sinjer
same results
Chup
you connect normally to Black Ops... Does it search for a game ? does it find games ?
"Attempting to connect to 3/47 games " ?
sinjer
Yup, it does that it keeps searching until i get "error no available sessions were found".
sinjer
and now i dunno why the game is updating...
